Ga door naar hoofdinhoud
4-inch iPhone uitgebracht in maart 2016 met hardware-specificaties vergelijkbaar met de 6S. Verkrijgbaar in Silver, Space Grey, Gold of Rose Gold met opslagopties van 16/32/64/128 GB. Model: A1662 en A1723
Bluetooth lost range after battery replacement
I just changed out my battery using a kit I bought here at iFixit. It was a bit of a struggle but I got it done. However, now when I connect it to my Bluetooth speaker it starts breaking up if it moves more than like a foot away. I think the wifi is affected too but it's hard to tell (my wifi isn't great normally). I'm a little worried I might have broken something. Should I go back in and replace the antenna or are there other troubleshooting things I should do first before I open the phone again?
Note: I have performed several hard resets but the problem seems to come back in different ways. I think it is a problem with the range of the antenna.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
You’ve bumped off or damaged the WiFi and Bluetooth antenna, which is that s shaped cable right above the battery.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
I opened it up again and that is exactly what happened. It got caught under the battery and snapped when I was putting the battery in. Always look twice before shoving something in everyone!
door
Voeg je antwoord toe
Pat zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 27
Altijd: 203
