Ga door naar hoofdinhoud
De mainstream iPhone 2019 van Apple, die 20 september uitkomt, heeft een 6,1-inch lcd-touchscreen, dubbele camera's en zes beschikbare kleuren. De opvolger van de iPhone XR.
20 Vragen Bekijk alle
Wireless Charging Stopped Working After Battery Replacement
I just replaced my iPhone's rear camera, battery, and lightning connector assembly in one go. The camera had focusing issues, battery health was at 78%, and it wouldn't charge by cable. Now, the camera works perfectly, battery is at 100%, and it charges through the Lightning port. Amazing, but wireless charging has stopped working! I've yet to re-seal the display and wanted to see if I missed a step and should backtrack, or if iFixit's replacement batteries just don't support wireless charging, as they're not recognized as genuine Apple batteries (which is what it says in Settings). The phone is running iOS 18.1.1, and I followed this guide.
Update 1: I did a quick search and learned that the black pad under the battery contains the charging coil. Maybe my placement of the new battery was off, though I thought it was fine, as the cable (circled in red) was properly aligned.
Update 2: Upon closer look at the video (specifically, around 8:40, after he removes the motherboard), I can see the connection from the gold plate on the wireless charging antenna's cable. That may be the issue. Will re-disassemble later and check for contact there. Hopefully it doesn't require removing the battery.
Update 3: Partially disassembled to check the wireless charging antenna's cable end, but didn't find any issues with it. My best guess is that I just damaged the wireless charging antenna's cable during battery removal, while prying under the battery for the adhesive. Can't fix that now, oh well!
Replace a 11.91 Wh battery compatible with iPhone 11. 3.83 Volts (V). Compatible with all iPhone 11 models. Afbeelding
Product
iPhone 11 Battery
$29.99
Replace a dual 12 MP rear-facing camera assembly compatible with the iPhone 11 model A2111, A2221, A2223. Fix sensor and focusing issues. Afbeelding
Product
iPhone 11 Rear Camera
$69.99
Replace a lightning connector assembly compatible with the iPhone 11. Includes the flex cable, logic board connector, lightning connector socket, and one microphone. Part #821-02037. Afbeelding
Product
iPhone 11 Lightning Connector Assembly
$24.99
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I've just accepted that I probably damaged the wireless charging component's cable while removing the battery. It would be too much time & effort to buy a replacement wireless charging antenna and take apart my iPhone all over again. At least the things I wanted to fix got fixed. You win some, you lose some!
Was dit antwoord nuttig?
Voeg je antwoord toe
Leon zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 13
Altijd: 37
