On/off switch wire colors
Which wires do I use to bypass bad switch?
Is dit een goede vraag?
Shorting the Pins:
To bypass the switch, you need to connect the green or blue wire (power wire) to the black wire (ground wire). These wires are usually located on the motherboard's front panel header.
Do not leave the pins shorted for more than a second, as that could cause electrical damage.
It’s important to replace the faulty power switch at your earliest convenience. If you're not comfortable doing this, or if it doesn't resolve the issue, it may be best to take the desktop to a professional.
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 13
Altijd: 206
