Ga door naar hoofdinhoud
De mainstream iPhone 2019 van Apple, die 20 september uitkomt, heeft een 6,1-inch lcd-touchscreen, dubbele camera's en zes beschikbare kleuren. De opvolger van de iPhone XR.
20 Vragen Bekijk alle
Does the battery kit have water seals
Does the battery replacement kit have new seals as you destroy the integrity of them
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi Craig,
If you're referring to the battery sold here on iFixit, then the answer would be, it depends.
They sell two different options; one is the battery by itself, and the other is called a Fix Kit, which costs an extra $5 USD.
The Fix Kit comes with all of the tools and parts needed to complete the repair, and in this case it does include the screen adhesive to secure and seal the display back onto the phone when you're done replacing the battery.
Be aware that any time you open up a phone the original IP water ingress rating is lost, whether it's done by you or a repair shop. Replacing the screen adhesive goes a long way toward sealing the phone against liquid, but there are no guarantees no matter what you do.
Was dit antwoord nuttig?
Score 3
2 opmerkingen:
In many iFixit cases also sells the adhesive separately!
door
@joshyacktman That is true for most phones they carry parts for and indeed, it is available for the iPhone 11, so good call Josh.
iPhone 11 Display Assembly Adhesive
door
Voeg je antwoord toe
Craig B zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 23
