Ga door naar hoofdinhoud
Released in January 2018, the ThinkPad T480s is a slim version of the T480 with the traditional trackpoint and three-button trackpad.
11 Vragen Bekijk alle
Thinkpad T480s Battery Replacement Compatibility
Looking to replace my Thinkpad T480s battery with this:
Lenovo ThinkPad T480s Battery - 01AV478
However, I don't see my model listed in the compatible devices list (20L8S49R00).
My laptop does use the same battery model though (01AV478).
Just wondering if it is compatible so I can go ahead pull the trigger on this because at the moment my battery barely lasts an hour.
Replace a 4708 mAh battery compatible with your Lenovo Laptop. 57 Watt Hours (Wh). 11.58 Volts (V). Part #01AV478. Afbeelding
Product
$69.99
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Hi @david66813
The battery you wish to purchase is compatible
Below is an image from the parts list for the laptop showing the part numbers for the batteries that are compatible with the model.
Note: the 2 substitutes for each battery shown in the list, are simply the other two listed i.e. any one of the 3 will work OK
If you haven't already got it, here's the hardware maintenance manual for the laptop. Go to the bottom of p.74 (81 of 113 pdf) in the manual to view the beginning of the built in battery removal procedure.
(click on image)
Was dit antwoord nuttig?
Voeg je antwoord toe
David zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 32
Altijd: 54
