Ga door naar hoofdinhoud
Repair and additional information for the GE GSS23WSW*** refrigerator, a side-by-side model without an ice through-door feature, equipped with an automatic defrost and an anti-sweat heater switch. This page covers information for model numbers matching the pattern GSS23WSW***.
1 Vragen Bekijk alle
Water dispensing issue - door feed seems clogged
The water is not dispensing from the door. Ice continues to be made. I changed the filter and the valve with no improvement. I decoupled the water hose at the bottom of the door and water is being delivered to the door. I am guessing there is no additional valve from the bottom of the door to the dispensor.I fished a wired from below through the dispensing hose thinking it was glogged - got through most of the length - no improvement. Could not fish it through the dispensor itself. I tried (using a waterpik) to fill the hose with white vinegar. It not not take any from above. Any ideas?
Is dit een goede vraag?
1 Opmerking
GSS23WSTA SS (side by side)
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
I have removed "stuff" from my dispenser right at the tip of the outlet hose with a small knife or other small probe.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Thank you. I reemed out the top of the dispesing hose (did not seem clogged) with a stiff insulated wire. It only went in about 1/2" past the bend. From the bottom, I was able to push the wire up the door near the dispensor.
door
Voeg je antwoord toe
Mark Creery zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 15
