Ga door naar hoofdinhoud
Ondersteuning voor de Texas Instruments TI-84 Plus rekenmachine.
Line of keys not working.
I've had my calculator for years and use it frequently. Today, an area of keys - specifically "0", "1", "4", "7", ",", "sin", "apps", "x^2", "(", ")" stopped working. All other keys work fine. I've tried restarting, system reset, and changing batteries. I don't know if it's possible water damage (I have cats) or something else.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
If a column of keys stops working that typically means it's a hardware problem. You might have success taking the calculator apart and cleaning the button side of the circuit board with isopropyl alcohol.
However, it's likely you'd also need to do a board level repair using soldering equipment. Water damage and corrosion can certainly cause issues like this.
Was dit antwoord nuttig?
Voeg je antwoord toe
Milo Moss zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 17
Altijd: 137
