Ga door naar hoofdinhoud
My laptop switches on but the screen is dark
Good day everyone.
May laptop switches on however the screen is dark,though with a flashlight I can see that the screen is on however it's dim,how can I fix that?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Sounds like LCD backlight failure, you can try replacing the LCD screen to see if it fixes the issue.
Was dit antwoord nuttig?
Score 1
B4 replacing the screen, verify the backlight/screen connector is secure (disconnect and reconnect it) and is being supplied with the proper voltage from the motherboard. Many HPs I have fixed by reseating the display connector. Often you can get to it by just removing the keyboard.
Voeg je antwoord toe
Ray Day zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 29
