Ga door naar hoofdinhoud
Repair guides and support for Kenmore washing machines.
20 Vragen Bekijk alle
Kenmore 700 series “lid” error
Kenmore 700 series, model 110.28102310
Problem
Washer is showing “lid” error on its display, despite the lid being closed
Troubleshooting steps
  • Original trouble came from a family member overloading the washer. This yielded a dU error code (door can’t unlock, even though the door was totally unlocked and free). I cleared this with a simple unplug and replug.
  • The dU code appeared intermittently and was resolved the same way for a few weeks until it finally would not clear on power cycle.
  • I don’t believe the issue is due to lid lock assembly. I’ve now replacethat (WPW10619844), but after powering it back up and trying to start any cycle, I get a “lid” error on the display for “lid left open,” which it is not. I cannot clear this error by any means. The original lid lock assembly now shows the same thing.
  • If I pull the sliding lock out through the strike plate, then turn on the washer, it will snap back through and show a dL error code (“door cannot Lock”). I can reset that by power cycle.
  • I don’t believe the control board is at fault, but I’ve ordered a replacement in case.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi @chadhendri94910
Here's the tech sheet for the washer that may help.
Perform a manual test of the lid switch and lock as per the Manual Lid Switch and Manual Lid Lock test on p.2 and also Test #8 on p.6 which checks the switch, the lock and the wiring from the control board connector plug to the lock.
If you find the problem and it is a faulty part that needs replacing, here's the parts list that is useful.
Locate the wanted part in the list and note the manufacturer's part number that is shown with it. Search online for the part number only to find suppliers that suit you best.
Was dit antwoord nuttig?
Score 1
5 opmerkingen:
Thanks, @jayeff — the tech sheet was a huge help.
Is there a difference between the Lid Lock and the Lid Lock Assembly? Test #8 references both, and I’ve replaced the Lid Lock Assembly (WPW10619844), so I think I have effectively replaced both.
door
@chadhendri94910
As best that I know the switch and lock are all part of the lock assembly.
Test #8 does also check if the wiring from the control board to the lock assembly is OK because the tests are conducted from the harness wiring plug (unplugged from the control board) back down to the lock assembly, thereby proving that the wiring and the switch and lock are all electrically OK from that point.
This doesn't mean that the lock (or switch) is mechanically OK although the tests done on p.2 should prove that.
If the initial manual tests don't work either for the switch or the lock, but test #8 is all OK, then it is either a faulty control board or a faulty lock assembly. I know you've replaced it but it can happen that you get a faulty part but then if it is OK, it's looking like a control board problem.
Perhaps check both the plug connector and the socket that it plugs into on the control board for corrosion and also the board for any obvious problems i.e. burnt out or heat stressed components
door
Ok, I’ve got a washer running, but more work needed to make it more reliable. Log (1/2):
* Lid lock assembly did not measure correctly with lid closed: I disconnected the harness from P12, the connector on the control board and probed as described in tech sheet. With the lid closed, the harness contacts did not show continuity across P12-1 to P12-5.
* I took apart my original lid lock assembly and saw it had a reed switch (SPST NO). Continuing to probe across those pins, I brought a small magnet near the reed switch and saw continuity. This tells me that the harness is probably OK and the magnet buried in the lid is maybe not.
* As a temp measure, I’m running the wash w/ a magnet sitting under the closed lid. Had to play around with position here.
* Although the lid locks correctly at cycle start, once the water has been filled it tests the lock again, and I’m getting a dL error here. So, I am also duct taping the lid while it runs just to hold it down. This lets me do my laundry from the last week+.
door
Log (2/2):
* The harness could still be bad. Specifically, the Reed Switch may not be in spec, so I may have to rework the board with a new one that is more sensitive.
* Since the original failure came after the washer was overloaded, I would expect a mechanical issue rather than an electrical one. It’s somewhat consistent to see a failure with a lid magnet, but I can’t really prove it yet. I tried to disassemble the lid but couldn’t get underneath to where the magnet is. Going to play around with that more this weekend.
* Additionally, I still have to bring the lid down to start the wash. Even with the magnet, it seems that the whole mechanism here is just very finicky.
* I’m not sure why I get dL in the middle of the cycle when it works fine at the start. The lid doesn’t seem like it moves much at all, so the lock shouldn’t have any problem with locking once it already has.
door
@chadhendri94910
You could always try bypassing the lid lock and see if the dL error still occurs.
door
Voeg je antwoord toe
Chad Hendrix zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 32
Altijd: 127
