Ga door naar hoofdinhoud
the Dell Dimension 8300 was a high-end desktop hailing from 2003. it has socket 478 processor support and came with 4 GB of ddr2 RAM
7 Vragen Bekijk alle
Dell Dimension has no power
I'm having the same problem. My system will not turn on. Replaced the power supply. Still will not power up. Could this be a bad power button? Any help is appreciated. Thanks!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi @tombell58613
Here's the service manual for the PC.
Select the Advanced Troubleshooting link on the Contents page and then check which diagnostic lights and their colour are turned on, on the back panel.
If there are any on, then depending on the colour combination, it represents a code showing what the problem may be.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Thank you for the manual. I will try the advanced trouble shooting & let you know what I find out. Thanks again!
door
Voeg je antwoord toe
tombell zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 15
Altijd: 34
