Why is it not turning on?
i was4 playing on my ps4 and it shut down and it doesn't work anymore
Is dit een goede vraag?
2 opmerkingen:
I assume the controller wont charge anymore either? Sounds like the battery has moved on. Swap in a different known working battery. If that works AND it charges just fine...then there's the culprit. However if a different battery works but does NOT accept a charge....the issue is somewhere in the charge circuit on the controllers main board.
door
It does work but on the charger only
door
Voeg een opmerking toe
