Ice Maker Does Not Fill with Water
Hello,
I have a GE Cafe French door with freezer below refrigerator. Model number starts with CFE28USH. It was in the house when we purchased the house (~2.5 years ago) and I am not sure of its exact age. Recently the ice maker stopped making ice. I replaced the triple valve that supplies water to the ice maker. This did not solve the issue. I verified (using a multi-meter) that the valve is receiving 120V from the control board when ice maker fill is called for. (This was done using the service menu on the device.)
Through door water is working fine. Hot water is working fine. I know the water valve on the line that connects the fridge to water source is working. When ice fill is called for I can hear a buzzing noise coming from the triple valve. Feels like it is coming from the water flow meter. Water flow meter is the very first item in the water supply system in the door.
Many of the things I have found online discuss a frozen tube. These seem to apply to models where the freezer is behind the door that contains the water tubes. Behind my door is the refrigerator component. Refrigerator temp is not see too low. Food/liquid does not freeze in the refrigerator.
Freezer temp is 2 degrees. Refrigerator temp is 39 degrees.
Interested to hear other thoughts or ideas on a solution.
Is dit een goede vraag?
