Ga door naar hoofdinhoud
The sixth generation of the Mazda Protegé, also known as the Mazda Familia and the Mazda 323. The five-door fastback edition was known as the Familia Astina or the 323F.
12 Vragen Bekijk alle
Why is my cooling fan not kicking on?
cant find cooling fan relay
Is dit een goede vraag?
Score 6
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
jeff, it is in the power box inside the engine compartment. Cooling fan relay is number 8. You also want to check the radiator cooling fan thermoswitch. That is the one on the thermostat housing and it controls the fan. Your Mazda has actually three sensors. One for the cooling fan, one to send a signal to the gauge, and one to send the signal to the ecu. number 2 in the second image is the engine coolant temp sensor. from here Hope this helps, good luck.
Was dit antwoord nuttig?
Score 3
i have mitubish outlander my cooling fan dont kick without turning on the aircoudition
2 opmerkingen:
alberto, what year is your Outlander? What engine and what type of transmission? You say "without turning on the aircondition" so it works when you turn on the AC?
door
My 1989 Mazda protege fans were working fine but I washed my engine and now they are not working what did I do to hurt the fans
door
I have this issue too. 97 familia, 1.5L manual.
Driving home the other day...bumped the kerb lightly as I parked up then temp light came on. Have tested relays, fuses, coolant temp sensor, thermostat ( all working as normal)....fans won't kick on at all.
This is really starting to do my head in.
Voeg je antwoord toe
jeff zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 39
Altijd: 12,476
