Ga door naar hoofdinhoud
Deze 5G-compatibele Moto G heeft een 6,5-inch 720 x 1200 pixels 90 Hz lcd-scherm, MediaTek MT6833-chipset en groothoek-50 MP-, macro- en dieptecamera's.
How to clean proximity sensor?
The display on the top side got unglued a few weeks back and I didn't bother to fix it. Now after ending phone call the proximity sensor turn off my display until I lock and unlock using buttons.
I believe it is due to some dirt accumulated on the sensor. What is the best way to clean it?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
I would run a hardware test on your phone to confirm this. There's a convenient iFixit guide for this. Secondly, you'll need to tear down the device a bit to clean it. I'm unsure if you'll need to remove the LCD panel, but there's a repair guide. You can clean it with some Q-tips and some isopropyl alcohol, but I can't give too much guidance on that.
If cleaning doesn't work, I can only recommend replacing the device's LCD frame or mid-frame housing. The mid-frame housing does contain some small components, potentially the proximity sensor. Also, it's essential to ensure you place proper adhesive post-repair.
Was dit antwoord nuttig?
Voeg je antwoord toe
Kishore Kumar S zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 15
Altijd: 370
