Ga door naar hoofdinhoud
Repair information and guides for the CDMA version of the fourth generation iPhone. Model: A1349 / 8, 16, or 32 GB storage capacity
20 Vragen Bekijk alle
Vraag afgerond
Screen replacement/home button,please HELP!
Hey guys,
I am doing a screen replacement on my iphone again i put a red one on it a while back but i am doing another one and i hate doing the home button.but this is what i want to ask you. could i take the gasket to he 4s home button and do it like that and just lay the ribbon cable down and set it up just like the iphone 4s?thanks
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I wouldn't try that only because your button is going to be pretty hard to press, and might not work at all, if you use that gasket.
The iPhone 4 home button really isn't that difficult, use a splunger to gently peel underneath the ribbon where it first makes contact with the plastic. When connecting the pins use a pair of tweezers, they are a HUGE help.
Hope that solves your issue.
Was dit antwoord nuttig?
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 796
