Ga door naar hoofdinhoud
Reparatiehandleidingen voor de Microsoft Surface Pro 8, uitgebracht op 22 september 2021.
FPC flex cable, Microsoft Surface Pro Signature
My Microsoft Surface Pro Signature keyboard suddenly stopped working, I tried several software solutions and nothing worked. Then I proceeded to disassemble the keyboard, and I found that the internal flex cable was damaged, as it had very small tracks, it was impossible for me to reattach them, and I ended up damaging the flex cable even more. Integrated in this flex are the backlight tracks, signal tracks and the tracks that power the wireless charging of the slim pen 2. The flex cable that connects the detachable keyboard to the tablet is broken, therefore the keyboard stopped working completely and it also does not charge the wireless pen. I uncovered it completely, and the flex is completely separated from the base of the external connector of the keyboard that is inserted into the tablet. I would like to know where I can get the schematics for this connector, know how the flex is connected to the connector pins, how the keyboard backlight is connected and how it is connected to the keyboard motherboard. or if anyone knows the function of the 6 pins of the connector, or if they could help me with some other solution. Please The FPC cable contains the following numbering: "MFS M1110070-012"
Afbeelding
Afbeelding
Afbeelding
Afbeelding
Is dit een goede vraag?
Score 3
1 Opmerking:
Hi Sebastian,
I have this same problem with broken flex ribbon exactly as per your photo. I am unable to repair the ribbon due to the extremely small tracks. Were you able to fix or source a new ribbon?
Thanks
David
door
Voeg een opmerking toe
1 Antwoord
FPC cable has 7 tracks. But connector has 6 terminals
Afbeelding
Was dit antwoord nuttig?
Voeg je antwoord toe
Sebastián Godínez zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 27
Afgelopen 30 dagen: 87
Altijd: 526
