Ga door naar hoofdinhoud
Rears break light doesn't turn on
Rear break light doesn't turn on
Is dit een goede vraag?
1 Opmerking
Hello San.
We are going to need more information about what happened.
What happens when you press the brake?
This is most likely a blown fuse, faulty connector or a faulty break light sensor.
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
@san38951 the very first thing you want to check all the fuses, the bulbs and the sockets for good connections. Next in line is your brake light switch. It is located under left side of dash, at the top of brake pedal. It's #3 in this image
Afbeelding
Make sure that the plunger of the switch engages or disengage with the movement of the brake pedal. You can also use a multimeter or test light to see if the switch actually activates (closes contacts) when you depress the brake pedal. Because of the location of the switch it's a PITA to work on this but it is not to complicated. Of course, you always want to check all the fuses, the bulbs and the sockets for good connections.
Was dit antwoord nuttig?
Score 2
السلام عليكم
Voeg je antwoord toe
San zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 37
Altijd: 404
