Ga door naar hoofdinhoud
Repair and disassembly information for Samsung's Galaxy A13 Android smartphone, released in March of 2022.
Why is it not charging?
why is it not charging?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi @mhretabarefayne
Have you tried a different known working charger or charger cable to check if the phone starts to charge?
Has the phone been dropped or gotten wet at all?
Use a strong light and a magnifying glass to visually inspect the charge port enclosure for any dust or lint that may be preventing a good electrical connection.
If there is any debris in the port enclosure, do not use a pin or probe to try and get it out as you may damage the pins or cause electrical problems in the phone. Try using a vacuum cleaner to suck it out.
If still no good the phone will have to be opened and inspected and tested as to what the problem may be. Here's a teardown video that may help with the disassembly
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Mhretab Arefayne zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 12
Altijd: 93
