Minolta Freedom Zoom 140EX Panorama Date not turning on
Hi,
I recently picked up a Minolta camera from an op shop, and put new batteries in (definitely the correct ones, model from the official manual(CR123A)), and it turned on and worked well, but I didn’t use it for about 3 weeks, and then it stopped turning on. When I press the power button, the display turns on for 1 second and then turns off again, although the date display is on. The lens is not opening, even though it is moving forward a tiny bit. The batteries are in the correct orientation, because they only fit one way.
Is dit een goede vraag?
4 opmerkingen
Hi @voydurwarranty
Try testing both of the batteries' voltage with a meter or try a new battery just to eliminate the possibility that one of the first battery( or batteries) has failed for some reason
door jayeff
Thanks, but I do not have a voltmeter/multimeter on hand. Is there any other way?
door Voyd ur Warranty
@voydurwarranty
Without a meter (do you know anyone who has one that they could lend to you?) you don't know the state of the batteries now i.e. good or depleted for whatever reason so the only other option is to try new batteries.
door jayeff
If the voltage is okay, what should I do?
