Ga door naar hoofdinhoud
Device repair information for the HP OMEN 15-dc0030nr, a 2018 gaming laptop manufactured by HP.
doesnt charge when in use but chargers when not in use
I bought a new charger for it but when I go to charge it my pc wont charge when its on and running but when I shut my pc it charges and charges in a hour i was told it was a new battery but i think that was a crock of crap
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi @maxdaplushuwu
I assume that you mean that you were told that the laptop requires a new battery, is this correct? If so, why do you "...think that was a crock of crap."? Have you proven that the battery is OK?
How long does the laptop run when only powered by the "fully charged battery"?
If not long then the battery may be failing and the charger can't do both i.e. run the laptop and charge the battery at the same time.
Create a battery report to check the status of the battery.
When you have the report, compare the Design Capacity value versus the Full Charge Capacity value shown in the report.
For a new battery they are the same value. The Full Charge Capacity value decreases as the battery ages.
You can work out as a percentage the condition of your battery by using the formula Full Charge Capacity value x 100 รท Design Capacity value. If the percentage is <35% it is advisable to replace the battery.
If it is determined that the battery needs replacing and if you have a HP OMEN 15-dc0030nr model laptop (as selected by you), then here's the maintenance and service guide, taken from this support webpage for the model that will help.
Go to p.45 to view the procedure to remove/replace the battery.
Search online for 917724-855 to find battery suppliers that suit you best. This is the HP part number for the battery used in the laptop. It should be printed on the battery if you wish to confirm.
Was dit antwoord nuttig?
Score 2
9 opmerkingen:
for the battery i was told it was new but ive heard that resellers take old batteries and just replace the cells in them and call them new and as for the pc itself its the same design but its a HP OMEN 15-dc0096nr
door
I also have to wiggle the charger port for it to charge. But I bought a brand new one
door
@maxdaplushuwu
Did you create a battery report as suggested above, you didn't say?
Do you mean that you bought a new DC-In jack for the laptop?
door
yes and yes ive done that
door
@maxdaplushuwu
What was the result of the battery report? Is the battery OK
Is the old charger still usable and can you try and see if it charges the laptop when the laptop is on?
door
4 commentaren meer tonen
Voeg je antwoord toe
Max da plush uwu zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 17
Altijd: 140
