The microphone does not work
Every time you want to use a microfont Every time I want to use the microphone it always doesn't sound right
Is dit een goede vraag?
2 opmerkingen:
Your phone uses different microphones depending on whether you're doing things like recording a video vs. talking on the phone. Which microphone is causing you problems?
door Deel
Hi @presleipan35235
Is the phone in a protective case at all?
If so try removing the phone from the case and check if the problem still occurs or not.
door Deel
Voeg een opmerking toe
