Ga door naar hoofdinhoud
De zevende iteratie van de iPod Touch van Apple, uitgebracht in mei 2019. Dit model wordt geleverd met maximaal 256 GB opslag en een A10-processor. Modelnummer A2178.
Battery removal is never mentioned
In all of the answers after step 22 -all the guides instruct to set aside the battery to the left. None of them say actually how to remove the battery in full.
How it is done? Thanks all- I just need to service the battery.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
The battery is soldered to th logic board, so you’ll need to have some basic command of soldering to remove it and replace with a new one.
If you have a look at the battery, it’s not like the other components that have a connector which snaps into something on the board. There is some tape covering the contacts on the board. You’ll need to desolder the connector here and solder on a new battery.
Replace a battery compatible with a 6th or 7th generation iPod touch model A1574 or A2178. Part #020-00425. Battery Model #A1641. 3.83 Volts (V). Afbeelding
Product
iPod touch (6th and 7th Gen) Battery
$19.99
Was dit antwoord nuttig?
Score 4
1 Opmerking:
Thanks- Fix-ability of this product seems low- I might not tackle it.
door
Voeg je antwoord toe
Paolo Alberto zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 37
Altijd: 496
