Ga door naar hoofdinhoud
Dit HP-model kwam uit in 2012. Upgrades zijn onder meer een anti-glare 15,6"-scherm en een vingerafdruklezer.
Battery in not charging
I used windows 10. Then it was showing plugged in (not charging) now i was installed windows 11. Now its not showing (not charging) but it was stucked at 1%. I was using my laptop with only ac adapter
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
If a device is plugged in but not charging, there are several possible reasons, including:
  • Your charging cable could be loose, unplugged, or damaged.
  • Your charging cable could have a weak connection because it wasn't made by your laptop's manufacturer.
  • Your charging ports could be clogged with dirt or debris that is keeping it from powering up properly.
Here are some things to try:
  • Check the connection: Unplug the charger from the device and the wall outlet, inspect the connection points for damage or debris, and reconnect the charger.
  • Check the outlet: Plug another device into the outlet to confirm it's working.
  • Try a different cable or charger: If possible, try using a different USB cable or charger.
Was dit antwoord nuttig?
Voeg je antwoord toe
Sabastin Cruzz zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 8
Altijd: 306
