Ga door naar hoofdinhoud
Model A1312 / medio 2010 / 3,2 GHz Core i3 of 2,8 & 3,6 GHz Core i5 of 2,93 GHz Core i7, ID iMac11,3
My problem is at Step 3
My problem is at Step 3, when I press the power button, the LED 2 lights up but when I leave the power button it turns off and the system also does not turn on. I have followed all the other steps after that and still nothing. Please suggest/help.
Thanks in advance.
Is dit een goede vraag?
2 opmerkingen
What happened with your system?
door
Hey there, Step 3 of what guide?
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Without more information it's hard to be certain what's gone wrong, but if you're only getting the first two diagnostic LEDs, then you may have an issue with the video card (something that is known to fail on the 2010 model). If the system is powering off immediately after releasing the power button, though, then that may indicate some larger issue, either with the power supply or the main logic board. Good luck!
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Dharmesh Thakker zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 178
