Ga door naar hoofdinhoud
Repair guides, disassembly, and troubleshooting information for the fourth generation Sony PlayStation 5 DualSense controller, successor to the DualShock series. Identified by model number CFI-ZCT1W and motherboard model BDM-040.
L3 button (sprinting) does not work after change of potentiometer
Hi,
Changed my potentiometer (left joystick) and it works great after the GUI installation. BUT, the toggle on the L3 does not work. I can’t sprint, and I have disassembled the controller 10 times, can’t see anything wrong. I really think I did a great job!
What to do here?
Is dit een goede vraag?
Score 1
1 Opmerking
How do I fix stick drift on my controller
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Hi!
Are you sure that it makes good contact inside the joystick? Maybe it's not pressing all the way in.
Can you share some pictures with us?
Anyway, if you tried everything and you just won't get it to work, I would just replace the left joystick. Saves you a lot of investigating and headache. And when you are there, maybe easier to replace it for a hall effect joystick?
Was dit antwoord nuttig?
Score 2
15 opmerkingen:
Yeah, I will try to post some pictures here this afternoon.
I’m thinking of byuing the gulikit joystick!? A bit expensive though. Feels like I could have just bought a new controller buy now haha.
door
Yeah those are great. They are more expensive but it's worth it. I fully understand yes haha. It's probably for the best to replace it tho..
door
It did not work so it must be the that little solder spot missing the cooper-ring,but we found the issue!
It is the same issue again everything works except Toggle L3 (B10 on gamepad tester).
So how do i find the right traces?
door
Indeed, the issue is found!
Here you can find some more info about that: https://www.reddit.com/r/soldering/comme...
door
[image|3429584]
door
10 commentaren meer tonen
I bought a secondhand controller with the right gen and switched the motherboard to match the controller. Works great!!
I think I &&^&@@ it up doing to much soldering on the solderpoints and ripped the copper ring.
Voeg je antwoord toe
Joakim Loso zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 140
Altijd: 1,670
