Ga door naar hoofdinhoud
De HP EliteBook 840 G4 is een slanke 14-inch laptop gemaakt voor werkende professionals. Hij draait op Intel's 7e generatie Core-processors, heeft een slanke aluminium behuizing en bevat solide beveiligingsfuncties voor zakelijk gebruik.
My battery died fast
my laptop battery died fast and its just charge for 80% and its died also when it close
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Hi,
Your laptop has been around since 2008 and I would suggest it has already had a battery replacement at some time in the past.
Depending on when it was last replaced, it’s more than likely the current battery is no longer capable of taking full charge or holding charge any longer.
If you have more recently replaced the battery it’s possible that it wasn’t a good quality battery or has developed an internal issue that affected its ability to perform as it should.
The other thing you may need to check is the charging power supply, as it may no longer provide enough charge voltage or current due to fatigue or cable damage.
You could try another charging plug pack & cable if you have access to one.
You may need to either have the charge pack & cable & battery tested at a repair shop.
Or if you know the battery hasn’t been replaced for a long time and your charging pack is functioning properly, buy a replacement battery.
Hope this helps
Was dit antwoord nuttig?
Voeg je antwoord toe
Mohammad Khair Al-Sairafi zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 10
Altijd: 206
