Ga door naar hoofdinhoud
16,2 MP Exmor R CMOS digitale compactcamera met 3,5-inch OLED-touchscreen, 3D Sweep Panorama en Full HD 1080/60p-video (zwart) Releasedatum: 12 januari 2011
Why is my camera don't on while charging
My camera don't on
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
@harsh56452 first you want to check your AC adapter. Make sure it has the proper voltage. Check to make sure the connectors are not bend etc. After that, check the charging port. Clean it of any debris etc, use a few puffs of air to clean it out. Make sure there is no corrosion, debris etc. that prevents it from working. If all of that checks out, you do want to go ahead and replace the battery. A depleted battery can no longer be charged and can possibly prevent the camera from coming on.
After that you will have to disassemble your camera and check the power circuitry on your camera. On your cameras SY-280 board are two fuses, marked F051 and F051. Those are the power supply fuses. Check those for continuity. If they have failed, your camera will not come on.
Afbeelding
Afbeelding
Afbeelding
You can now get the service manual on the bottom of this page Sony Cyber-shot DSC-TX100V Check under documents.
Was dit antwoord nuttig?
Voeg je antwoord toe
Harsh zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 12
Altijd: 230
