Ga door naar hoofdinhoud
Deze iteratie van Amazon's Kindle Paperwhite-serie werd uitgebracht op 30 juni 2015. De Kindle Paperwhite 3e generatie is een 6-inch e-reader met een display van 300 PPI die beschikt over wifi. Het aangewezen modelnummer is DP75SDI.
My screen is stuck at language setup screen.
Hi Team,
My Kindle was stuck all the time on home screen.
When I press power button it would popup option to restart, shutdown cancel however I was never able to select it.
Out of frustration I followed an article on Internet "Doing Factory reset using computer"
I created File without extension Do_Factory_Restore transferred to kindle performed factory reset.
Now my screen is stuck at language setup page.
  • I am unable to select get started 😑
  • I tried pressing hardreset for 40sec no joy.
  • I tried connecting kindle to computer it shows drive is not ready😓.
  • I have put my self in helpless situation.
Is dit een goede vraag?
3 opmerkingen:
Is the touch screen working? It could be a screen issue.
door
Touch works on limited area rest feels like screen Is dead
door
It’s possible half the screen is dead , most probable in-fact as it’s a strange screen to be stuck on. Have you dropped it any marks or damage on or around the screen? I’m weirdly convinced my below answer will fix this.
If your not confident you could always take it to a repair shop for second opinion/ repair.
door
Voeg een opmerking toe
2 Antwoorden
If you cannot do anything on the screen it is most likely a damaged digitiser. This can get damaged by a short fall or bump in the wrong place . Here’s a full guide and what to get.
Kindle Paperwhite 3e generatie scherm/touch screen vervangen
Was dit antwoord nuttig?
Try to turn off the screen using the power button and long-press it for a few seconds. If this doesn't work then try charging it for sometime. Restart your Kindle to resolve the frozen issue.
Voeg je antwoord toe
Ashley John zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 12
Altijd: 331
