Ga door naar hoofdinhoud
A1708/EMC 3164 — Released June 2017, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar).
Trying to use terminal to disable auto boot
Can’t get terminal to disable auto boot using sudo nvram AutoBoot=0%
Seems like nothing happens after imputing me password
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Are you following the steps in this guide? Note also that when the command executes successfully it doesn't really give you any feedback, it'll just go to the next terminal prompt. You can check to see if the command was successful by shutting down the device and closing the lid. Then open the lid and see if it auto boots. If it doesn't, then you're good to go! Good luck!
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Blair Aston zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 10
Altijd: 80
