Ga door naar hoofdinhoud
Apple's top-of-the-line smartphone for 2020. Announced on October 13th and released November 13th, the iPhone 12 Pro Max sports a 6.7" OLED display, a triple rear camera system with LiDAR, and 5G connectivity. Successor to the iPhone 11 Pro Max.
Power button is like always pressed.
Hi, some water went inside my customer iPhone and now is like the power button is always pressed. I tried to disassemble it, removed the flex part and the button, tried to clean it. When i turned on the phone, while it was still open, the button was working again, but when i closed it didn't turn on. I put it to charge, was turning on automatically but only opens the itunes restore screen.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Hi there I’d replace the flex cable, and maybe the button too just for the sake of ruling out both.
A new flex should fix it though. If it doesn’t then maybe water got somewhere else also.
Main priority flex cable before anything else.
Also check screen frame isn’t bent near it causing it to play up when in place or snagging it up. Still replace it though even if it’s the frame, unless it fixes the issue of course.
Was dit antwoord nuttig?
3 opmerkingen:
I tried by replacing the screen (because the old was broken too) but nothing, the stangest thing is that sometimes it works, but most of the times no.
door
Yeah without seeing it I’m 80% plus certain changing flex should fix it . It’s not the flex itself more the button part of the flex. It’s not uncommon issue with iPhones in general.
door
Obviously where water is involved you can never rule out a board issue. I have personally taken pictures of severely water damaged corroded phones and boards when they were advertised as waterproof! . I personally consider a water proof phone as ‘splash proof’ . Your issue is likely the power button flex/ button itself.
The difference between a good button and a bad one is literally fractions of a mm. it should feel springy and punchy not like it’s pressed in and dull.
door
Voeg je antwoord toe
ToToMalux zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 21
Altijd: 360
