Ga door naar hoofdinhoud
Reparatie- en demontage-informatie voor de Rakuten Kobo Clara BW (zwart-wit) eReader, uitgebracht in april 2024. Te herkennen aan de modelnummers N365, N365B of P365.
Need SD card full image
Does anyone have a full SD card image for Kobo Clara HD N249 model? My sd card is working anymore, I need to image a fresh SD cars. I have no previous backup.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
Sorry I have not been following the forum for a while. I have used this image. You can download from mu google drive:
https://drive.google.com/drive/folders/1...
Was dit antwoord nuttig?
Score 1
Het nuttigste antwoord
Hi,
I’ve had a quick look around and found firmware available for download from the pgaskin website.
https://pgaskin.net/KoboStuff/kobofirmwa...
There seems to be lots of options for firmware upgrades for different models.
Hope this helps
Score 1
3 opmerkingen:
Also images available for kobo here:
https://www.mobileread.com/forums/showth...
door
This is a good tutorial on flashing images and using the right formatting tool (windows won’t work apparently)
https://m.youtube.com/watch?v=hRdV5ukt_Q...
door
hi. How can i burn the image? is a zip file with other file inside
door
did you found something ?
Yes, I have found a working image. A friend of mine helped me flash it and it works.
14 opmerkingen:
hi! i have the same need.. full disk image for my n249 clara hd. can someone help me
door
Hello, same problem for me, would someone charitable please send me a picture for my Clara HD, thank you.
door
@jmrousseau Did you get a response?
door
no answer unfortunately:(, you any luck?
door
@jmrousseau oui j ai recu le liens d un autre forum
door
9 commentaren meer tonen
Voeg je antwoord toe
Ozzy Aslan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 12
Afgelopen 7 dagen: 86
Afgelopen 30 dagen: 2,281
Altijd: 7,302
