Ga door naar hoofdinhoud
Samsung 75" tv uit de UN-serie.
How to repair screen
How to repair the screen
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
The issue with TVs isn't that they can't be repaired; the LCD usually costs as much as an entire TV :/. Even when the TV is current, the panel tends to be a "total loss" failure.... It gets worse when they become last year's model, without fail. Unless it's an LED array failure you can recover from with a set of donor strips, I've never seen anyone successfully repair a TV with panel issues.
Your best bet is to take the TV apart and look up the panel number; you might get lucky. That said, TVs are generally not cost-effective for panel replacements, and you're usually better off selling the parts that still work to offset the replacement cost.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Abebaw Simachew zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 14
Altijd: 295
