My computer is restarting
My computer restarting everytime I turn it on. It does because when I was resetting it I suddenly cut the power off and now it is restarting everytime please I need a solution
Is dit een goede vraag?
You likely have corrupted files. So start with try the following. If you can't get into the Advanced Startup you may have to use a USB Windows Setup flash drive instalation media to run Advanced Startup. If you don't have Windows Installation Media then you can download and create it from a working computer by going to the website http://www.microsoft.com/software-dow... and clicking on your version of Windows and click on "Download Tool Now".
Accessing Advanced Start-up when PC isn't loading:
If your device isn't loading or stuck during boot, you can use this method to access the recovery environment:
After the third interruption, Windows 10 will open into the Advanced Start-up environment
While in the Advanced start-up environment, use the following steps to use Start-up Repair:
If the above doesn’t help do the same as above but this time select “System Restore” from the “Advanced Options?”
Run following:
SFC /scannow(Note: Repair Windows 10 - "you need to sign in as an administrator to continue, but there aren't any administrator accounts on this PC"
Was dit antwoord nuttig?
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 17
Altijd: 259
