Ga door naar hoofdinhoud
27" display with 2560 x 1440 pixels resolution Thunderbolt & MagSafe cable attachments
160 Vragen Bekijk alle
power supply board replacement part
i'd like to get a power supply board (flextronics) for my 27" thunderbolt display. are these for sale? are they same is what is in a 27" iMac?
Is dit een goede vraag?
Score 5
7 opmerkingen
Hi aaronoehlke. Did you find the power supply board for sale?
door
I also need this - it makes a weird noise - and it is coming from the power supply...
door
Have you got the power supply?
door
Hi Karsten,
Nope - have you got one in Denmark?
door
Unfortunatly not!
door
2 commentaren meer tonen
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
This should still be under warranty. If it is, I would certainly get the extended AppleCare warranty.
Was dit antwoord nuttig?
Score 3
Hi
Power supply board part numbers are: 661-6048, 661-5543. I found boards available for sale on ebay and maybe available for other apple spares suppliers if you search using the part numbers.
Score 3
2 opmerkingen:
Will both power supply board with the different part numbers be compatible for a Thunderbolt Display?
door
The question is still open, are those part numbers interchangeable or: what's the difference?
door
Voeg je antwoord toe
aaronoehlke zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 6,651
