Ga door naar hoofdinhoud
The first model of iPhone, Model A1203 with 4, 8, or 16 GB capacity and an aluminum back. Repair requires a significant amount of prying, and may require some soldering. This page aims to help users troubleshoot, fix, and seek help for the iPhone 2G.
20 Vragen Bekijk alle
Air bubbles after changing screen
I`ve tried to change screen on my iphone 2g, which was full of bad pixels. I bought a new one on ebay and followed instruction video on youtube, but after connecting everything back the screen looked like this(photo). What have I done wrong? Can this problem be solved somehow or I have to buy a new screen?
Thanks in advance
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Driver733, I am hoping you replaced it as an assembly, not as individual pieces. If you replaced it as an assembly, contact your vendor. This is a manufacturing defect and ask for a replacement or a refund. this is not something that you have done.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Thanks for your answer. Here`s the item I bought (http://tinyurl.com/d5h8lfb) The seller told me that it is OEM. Could you please take a look on this item and say if it`s OEM or not.
door
It is hard to determine if it is OEM or not. This is something that a lot of vendors are saying. The problem here is that air got trapped when the LCD and the glass were bonded. Poor quality control has become a major issue. Hope this helps, good luck.
door
Voeg je antwoord toe
DRIVER733 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 643
