Diode burnt on power supply
I am thinking this is a diode? I looks like it's toast anyone know where I can get one to replace it?
Is dit een goede vraag?
@maxxilian you could simply test it with a multimeter to see if it is "toast". You also want to take a look at the underside of the board. There may be other components that are "toast" as well. AS for the value, once you desolder the diode you should see what the numbers following the "IN" are. Based on that, you will know what type of diode you are looking at.
Let us know what Xbox this is out of and where this board belongs to. Looks like the power supply but can't be sure on that. Typical diode for that would be a general purpose (1)IN4006
Mouser.com as well as Digikey.com are my go to for components however, you can get those wherever you usually purchase your repair components
Was dit antwoord nuttig?
Thanks for the reply, I tested it and it has failed. Checked around and tested anything close to it they are fine. i will check out those sites as well TYVM
Afgelopen 24 uren: 12
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 12
Altijd: 12
