Why my phone is not charging
My phone is not charging
Is dit een goede vraag?
@anmolsotang you are really not giving us a lot of information here. It is always nice to know if anything has happened to the phone and what you have tried and checked to fix this.
First check your charger. Make sure it has proper output. Then check your charging cable. Check to make sure connectors are not bend etc. After that, check the charging port. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get a USB ammeter and see if your phone draws any amperage from the charger. If it does not it is possible that this is a charging port issue or a bad battery.
To check the charging port, use a voltmeter and measure the voltage on your battery connector. Next plug your phone charger in. Now measure the voltage on your battery connector. That voltage will have to have increased. IF not then the issue is either the port or the charging circuit.
Also check the flex cables coming from the charging board to the main board. Check that for micro tears and corrosion and proper connection to the boards. I suggest that you start with a new battery if any of the above did not work. After that it's the charging board and flex cables.
Since iFixit does not yet have any specific guides for that use something like this video. Replacement batteries and charging boards are readily available at many online stores.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 3
