Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Officieel gelicentieerd Joy-Con-alternatief voor de Nintendo Switch. Uitgebracht in september 2019, herkenbaar aan modelnummers NSW-182 en NSW-182U.
Left stick not taking up inputs
So for some reason whenever I hold up with the left stick on my split pad pro, it just stops taking the input for a split second repeatedly. So for a few moments I can have the input be fine, but then it just stops for a split second. Does anyone know why this happens and how I can fix it?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
This sounds like the same kind of issue you would see with joystick drift. Please see my answer below for that repair.
Drift is a common problem with all joysticks. The best way to solve that problem with with a joystick replacement. The Hori Split Pro appears to be compatible with Xbox joystick replacements like can be found anywhere you search for "xbox joystick replacement". For example: https://a.co/d/5AmYLY1
The existing joystick would need to be removed/unsoldered and replaced with a new joystick. This is a common repair for any controller with a joystick. Search YouTube for thousands of videos on how to do it.
Was dit antwoord nuttig?
Voeg je antwoord toe
CJ BlueThunder zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 17
Altijd: 328
