Ga door naar hoofdinhoud
Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Vragen Bekijk alle
Do I need to replace partially torn audio jack cable (interior)?
While doing a combo power and sensor cable/dock connector repair (I tore the dock connector completely while peeling it back) I noticed a small half-tear to the black cable attached to the audio jack that connects to the logic board. Will this function in its current state or do I need to replace it?
Here's the picture- http://i1015.photobucket.com/albums/af27...
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Tom, I would suggest that you fix what is broken. I would honestly not expect it to work if it does not get replaced/repaired. Broken, even partially broken, parts usually cause you more trouble later on. Replace it now and be done with it. :-) Just my 2 cents, good luck
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Thanks for the advice. Also, do you think you could take a look at this question? I'm having trouble with the front-facing camera. iPhone Front camera won't fit into place..
door
Voeg je antwoord toe
Tom zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 324
