How to fix a battery that drains quickly and fills slowly when chargin
How to fix a battery that drains quickly and fills slowly when charging?
Is dit een goede vraag?
Hi @karneti
Replace the battery in the phone and check if that resolves the problem.
Here's a video that shows what to do.
Search online for BN62 battery to find suppliers that suit you best. Check the model number on your battery to make sure that you're looking for the correct one
Was dit antwoord nuttig?
To fix a battery that drains quickly and charges slowly:
1. Calibrate the battery: Drain to 0% and charge to 100%. Repeat this process 3-4 times.
2. Check for battery health: Use built-in diagnostic tools or apps like BatteryMon or Coconut Battery.
3. Update device software: Ensure the latest updates are installed.
4. Close resource-intensive apps: Regularly close apps that consume excessive power.
5. Avoid overcharging: Keep the battery level between 20% and 80% if possible.
6. Clean battery contacts: Corrosion can affect charging efficiency.
7. Consider replacing the battery: If it's old or damaged, replacement may be necessary.
Remember, battery performance can degrade over time. If issues persist, consult a professional or the device manufacturer for further assistance.
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 10
Altijd: 10
