Ga door naar hoofdinhoud
De Nintendo Switch is een draagbare spelconsole die via een dockingstation op de tv of onderweg kan worden gespeeld. Uitgebracht op 3 maart 2017.
fix for wonky joycon R-button?
About a year ago the R button on one of my sets of joycons started acting up. Sometimes it double presses, sometimes it doesn't register being pressed, and sometimes it gets stuck. I switched to my other pair but now it's having the same problem.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi Noah!
Okay, so the other set of joycons are having the same issue? I still think it's Joy-Con related, because the same issue came up later on and not immediately.
Unfortunately, the right Joy-Con does have the actual button soldered on the motherboard...
Now, there are 2 things to do, to get it working again. If the button didn't fall of the motherboard (this is a common issue for the Right Joy-Con). If this happened, then it's for the best to replace the motherboard.
Option 1: De-Solder the R button from the motherboard and solder a new one in (this can only be done if the traces are still OK).
Option 2: Replacing the motherboard (this is more expensive, but easier).
R button part: https://www.aliexpress.us/item/325680520...
Motherboard part: https://www.aliexpress.us/item/325680689... (A2 is right).
Good luck with the repair and please let us know how it goes!
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Noah A zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 28
Altijd: 734
