Hisense Television LEDN50K300P doesn't show pictures
My television just went blank. When I switch it on the sound does come out but doesn't show pictures. What might be the problem?
Is dit een goede vraag?
@qsquaredat it's a Hisense, so the very first thing that comes to my mind are the backlights. Hisense uses some really crummy LED's
Try this first. Turn the TV to a channel where you can hear the sound. Next, use a flashlight and shine the beam at an angle against the screen. Do that in a darkened room. See if you can make out shadows or shapes. If you do, then it is your backlight that has failed. If you do not see anything, unplug your set and remove the back cover. Then visually check the boards for any obvious damaged components. Check all the wiring and unplug the wires and plug them back in, make sure they are properly seated. Post some images of all of your boards with your question. Use this guide Voeg afbeeldingen toe aan een bestaande vraag for that so we can see what you see. It is possible that this then is either a power board or a T-con board issue. (main board if your TV does not have a dedicated T-Con board.)
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 7
Altijd: 7
