Ga door naar hoofdinhoud
De 15" MacBook Pro (model A1990) werd uitgebracht in juli 2018 en is voorzien van een 15,4-inch led-display met achtergrondverlichting en True Tone-technologie, TouchID en maximaal een 6-core i9-processor.
Need help diagnosing display issues
My 2018 MacBook Pro display is shpwing flickering green and red lines, and occaionally blacks out or has a block pattern. I cannot locate any cracks in the screen, and the laptop has not been dropped since I have owned it. Graphics display perfectly when using Airplay to cast to my TV. Does this seem to indicate a display cable issue, or should I be looking at replacing the screen? Thanks in advance for the help.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
This is most likely due to a failing display flex cable, which unfortunately is integrated into the display assembly. This is a common design problem with these models (2016-2018ish Pros). Unfortunately you'll need to replace the display assembly to repair the device. Sorry!
Was dit antwoord nuttig?
Score 1
1 Opmerking:
That’s what I thought originally, I just needed some confirmation before I under the process. I already bought a replacement display as simply, I just had not installed it. If there was any other options, I wanted to explore that first. Thanks a bunch!
door
Afbeelding
Saludos que me recomienda MacBook Pro 2018 15 pulgadas modelo a1990
Voeg je antwoord toe
Tanya Robinson zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 23
Altijd: 259
