Ga door naar hoofdinhoud
De SSL 2 is een USB-audio-interface die in januari 2020 is uitgebracht. Het apparaat maakt gebruik van hoogwaardige componenten en is zeer eenvoudig in gebruik.
My line and Hi z button
When I press the buttons it makes static noise is there a way to fix this and how much or should I just buy a new unit
Is dit een goede vraag?
Score 2
6 opmerkingen
I noticed this on my SSL2 also yesterday, approx 2 years old, in daily use with a line input, but rarely adjusted. Even moving the switches a little side to side causes crackles. Sometimes I would take my hand away and it would be left sounding very degraded. Planning to check if this is just the channel I use, or both. The case is dusty so I might also try taking off the front plate and using an air duster spray in case anything got into the switch mechanism
door
Looking for spec on the buttons as I think I need to replace one
door
So you have n same problem with line buttons 🤔
door
@tim75649 i just did an overhaul as both my phantom power buttons were activating/deactivating with just the slightest touch. I re-flowed the solder joints and sprayed a bit of contact cleaner while I was in there. The combination seems to have solved the issue. For now. Di you have luck by just using the spray duster?
door
@petegunns i just did an overhaul as both my phantom power buttons were activating/deactivating with just the slightest touch. And every button was staticy. I re-flowed the solder joints and sprayed a bit of contact cleaner while I was in there. The combination seems to have solved the issue. For now.
door
1 commentaar meer tonen
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
It's dust I use vacuum cleaner to clear dust over knobs and buttons before I turn on it work no more cracklen 😁 but have to repeat as needed but crazy thing is my gear is always covered with plastic and blankets when not in use 🤔
Was dit antwoord nuttig?
Score 1
3 opmerkingen:
Hi @petegunns
It may be better not to cover in plastic or at least not plastic that is not the anti static type.
Most non anti static plastics can generate static electricity which attracts dust.
door
Even if it's the plastic it came in 🤔
door
@petegunns
Plastics that generate static attract dust so unless it is perfectly sealed it will get in somehow.
I would try an anti static cloth covering and check if that worked any better.
door
Voeg je antwoord toe
Pete Gunns zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 56
Altijd: 1,155
