Ga door naar hoofdinhoud
Water coming from wall air conditioner
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
@kingisgameing what kind of air condition? what make and model? What have you checked? You do recognize that the first this you want to check is the condensate drain. If it is clogged, your AC will drain wherever it can and that can even be inside your wall. First thing to do, check the condensate drain line!
Since we do not know what type AC and what make and model you have we can't give you exact details on where to check that line. For a Mini-Split AC it is commonly behind the plastic panel that holds the filters.
Was dit antwoord nuttig?
Voeg je antwoord toe
King is Gameing zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 27
