Ga door naar hoofdinhoud
Released August 2003. An expensive, but high-end laptop of its time.
6 Vragen Bekijk alle
Why won't it boot up
press on button. green light comes on, screen flashes (sometimes) then it's dead
Is dit een goede vraag?
Score -1
2 opmerkingen
Anything happen to it? Do you get any sign of the POST? What have you tired so far to fix it? Have your tried an AC adapter?
door
i'm back on with the machine in question maybe graphics card? don't know alot, is there some diagnostics i could run through it?
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
henge, you might want to check on here. Those Dells' are prone to failure, especially the hard drive. Check your RAM as well. Good Luck.
Was dit antwoord nuttig?
Score 3
4 opmerkingen:
came on after many attempts a month ago getting less reliable in switching on, runs great when its going but now it wont start. battery seems fine. thanks for takin the time.
door
Do any of your LED's come on or do they blink? Have you tried an external monitor to make sure that it is not just your LCD?
door
Here is the service manual for your computer http://www.elhvb.com/mobokive/edwin/lapt...
door
thanks for trying old turkey, I'll let it hibernate through summer and look for another.
door
Voeg je antwoord toe
henge zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 10
Altijd: 1,333
