Ga door naar hoofdinhoud
The HP Elitebook Folio 9480m was released on July 4, 2014. The 9480m model can be identified by model number J5P80UT.
How to change screen to my laptop?
screen change
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi @itiplayz92
Here's the maintenance and service guide for the laptop.
Go to p.50 to view the procedure to remove/replace the display assembly. See Step.5 on p.51 for how to replace the LCD panel.
At the top of p.50 you will find the HP spare part numbers for the 2 LCD panels that can be used in the laptop.
Search online for the part number only of the LCD panel applicable to your particular laptop version, to find suppliers that suit you best. Usually the part number is located somewhere on the back of the LCD panel itself, if you wish to verify that you're getting the correct one.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
itiplayz 92 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 119
