Ga door naar hoofdinhoud
The HP EliteBook x360 1040 G5 Notebook PC features a choice of Intel Core processors, including the i7-12700H and i5-12500H.
10 Vragen Bekijk alle
Why Is my pc failling to complete powering on?
My laptop is unable to power on, It runs some file scanning with an endless scanning after there it displays the trouble shooting how can I get help with this.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Without better info, it sounds like your boot sector is messed up or you have bad system files.
Either way, it will require a reinstall of the OS. You may be able to do a repair install. But first you need to download and create a Windows USB flash drive. Then boot from that and follow directions.
A repair install will not delete your files. A clean install will delete everything. If you need to recover your files (no backups) then you must remove the drive and connect it to another computer using an external drive enclosure. However, it may not register on the other computer if the boot MBR is bad.
Was dit antwoord nuttig?
Voeg je antwoord toe
Joseey Joseph zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 61
