Ga door naar hoofdinhoud
The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
1198 Vragen Bekijk alle
How to properly clean touchpad without causing damage.
Okay, a while back I asked about my trackpad, cause it had decreased skills after a battery replacement.
But I have now noticed that it feels rather different, in terms of 'it feels like theres stuff on this'
Upon noticing this I had a theory, and promptly tested it.
Only some areas on the touchpad feel off, (mainly centre where I usually use it)
Outer edges of touchpad feel fine, and the performance is 100% fine, but the centre, it doesn't fully register my touches all the time.
So anyways, how would I clean the touchpad?
Some details for you:
I do not have the tools and resources needed to fully remove the touchpad (aka, remove battery to get at it, as I don't have an adhesive remover, nor extra adhesive to put the battery back in.)
I do have 99% iso alcohol.
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Cleaning the touch surface and the narrow gap around it is about all you can do without removing the touchpad.
Start off just lightly wetting a cotton face pad with the 91% isopropyl alcohol it only takes a drop or two as you don’t want it too wet which could seep into the layers of the touch surface. To clean the edge I just run a business card or thick paper that slides in. The goal here is to push out the grit.
If neither offers any improvements you’ll need to remove the trackpad to then use the cotton pad to wipe edges of the frame and trackpad again watch the wetness! Don’t over do it.
Was dit antwoord nuttig?
3 opmerkingen:
Will give this a try once I get the chance!
I notice that you said 91%, but would 99% still be okay to use?
door
@danj - I do fully suspect the fact that the problem is caused by a build up of dirt and grime.
As for the battery, I missed that bus, replaced it a month ago! And I would rather leave the battery be as it’s working just fine and I don’t have the tools to remove it and put it back in.
I will also fully admit that I haven’t been as good with my computer as I usually am, in terms of making sure to not get the trackpad and keyboard dirty. Life has decided to throw some major and difficult to deal with things at me, for 6 months straight. And as a result I do admit that my poor computer has been a bit neglected in its care.
door
@computermoth - I get it, life and it’s events controls one’s time offering little to deal with the maintenance of things.
Apples engineering may be great from the outside, but still has along way internally! Even the assembly process could be faster with better human engineering (even with automation too). The easier it is to assemble often makes an easier system to service!
door
@computermoth this model has a haptic-capable "Force Touch" trackpad. You may need to consider having to find a way to perform a Trackpad Calibration Check The biggest challenge will be that it is cloud based and you must log into GSX first. Most likely you will not have access to that. Here is more about the AST 2 Procedures
You may just have to get used to working with what you got or hit up Apple up and inquire about having them do it.
8 opmerkingen:
@oldturkey03 - Perhaps, I’ll point out that my main issue is with moving the mouse, like swiping.
Clicking is fine.
Dragging is fine.
Double tap is fine.
Lightly moving finger over the trackpad to move the mouse from point A to point B is where it decides to be difficult with me. But it only does this in the middle of the trackpad, say for example I drag my finger from the top left corner to the top right corner, no issues.
I’m also aware that some types of trackpads have a sort of coating or something that can rub off over time, I’ve seen this firsthand on a couple thinkpads. But I’m not sure if the MacBook is like that in terms of trackpad design.
door
@computermoth anything is possible, just difficult to troubleshoot.
door
@oldturkey03 - Indeed, I’m planning to try Dan’s suggestion first, and well, if nothing changes, I guess I’ll look into troubleshooting it.
door
@oldturkey03 - First off AST is an Apple tool and only authorized service providers have access to it. Even the newer version has its limits as any 2015 and older systems are not supported within it and so far the supported creep is now at 2018 systems and newer. So that doesn’t help us here either. While Apple has opened a crack (a small one) only M series systems and newer are covered with the open version of AST2 as of today.
Just like the openness of the service manuals is only M series Apple doesn’t offer older stuff and they are now altering the manuals to be web pages Vs a PDF! Which puts their availability at risk when they decide to stop posting it unlike a downloadable PDF (and how the older Apple manuals where made available to the authorized servicer’s and how many made it to the public ream. Lastly, even today not everyone has a nice internet pipe to access the Apple servers nor should we allow them to gain metrics on the folks who do access these servers and what they are reading.
Just like books we don’t allow the publishers access to what I buy and why I choose to read within it.
And lastly, the calibration steps is not practical for most and you still need access to AST the test tool and weights to preform it. You just as well just replace the trackpad at that point.
door
As to the trackpad very true! It is not a mechanical touch surface like older units. The reason to clean the edge has to do with skin oils and salt buildup which tends to collect along its edges. The effectiveness of the capacitance drops off often from this dirt. Taking it out is the last direction as you need to deal with the removal of the battery! If the battery also needs replacement is really the only time I go that far giving it a good clean.
door
3 commentaren meer tonen
Cleaning your MacBook Pro's touchpad carefully is crucial to avoid causing damage. Since you have 99% isopropyl alcohol, that's a good choice for cleaning. Here’s a step-by-step guide to clean your touchpad safely:
  1. Materials Needed:
- 99% isopropyl alcohol
- Microfiber cloth or lint-free cloth
- Cotton swabs (optional)
  1. Steps to Clean the Touchpad:
1. **Power Down Your MacBook:**
- Turn off your MacBook and unplug it from any power source.
2. **Prepare the Cleaning Solution:**
- Dampen a microfiber cloth or lint-free cloth with a small amount of 99% isopropyl alcohol. Do not soak the cloth; it should be slightly damp, not wet.
3. **Wipe the Touchpad:**
- Gently wipe the touchpad with the damp cloth. Focus on the areas that feel off or have decreased responsiveness.
- Use a circular motion to clean the entire surface of the touchpad, ensuring even coverage.
4. **Clean the Edges:**
- If needed, use a cotton swab dampened with isopropyl alcohol to clean the edges and corners of the touchpad where dirt and grime might accumulate.
5. **Dry the Touchpad:**
- Allow the touchpad to air dry for a few minutes. Since isopropyl alcohol evaporates quickly, this shouldn’t take long.
6. **Test the Touchpad:**
- Power on your MacBook and test the touchpad to see if the performance has improved.
  1. Additional Tips:
- **Avoid Excessive Moisture:** Ensure the cloth is not too wet to prevent liquid from seeping into the device.
- **Regular Maintenance:** Regularly clean the touchpad to prevent buildup of oils and dirt.
- **Avoid Harsh Chemicals:** Do not use harsh chemicals or abrasive materials to clean the touchpad.
  1. If the Problem Persists:
If cleaning doesn't improve the touchpad's responsiveness, there might be an underlying issue related to the battery replacement or another hardware issue. In that case, consulting with Apple Support or visiting an authorized service provider would be advisable.
Voeg je antwoord toe
Moth zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 27
Altijd: 110
