Ga door naar hoofdinhoud
Reparatiehandleidingen en informatie over het demonteren van de 14-inch MacBook Pro die in oktober 2021 werd uitgebracht, uitgerust met door Apple ontworpen M1 Pro- en M1 Max-SoC's. Model A2442.
Ordering a replacement screen in Canada
I was curious about my ability to use the calibration tools when ordering a replacement display in an unsupported country?
I'm in Canada, and I have a US<>CAN shipping service I use frequently to order US items that don't directly ship to Canada. So getting the display should be no issue. But I wasn't sure if I would have problems using the tools to calibrate the display.
Has anyone in Canada used the tools? People mention running them through a VPN, but I just wanted to confirm if anyone's actually done that successfully.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Good question! I think you'll need to use a VPN which has a US IP address to make sure it goes as intended.
If you do try to get it to work with a Canadian IP and it works let us know! Otherwise its the VPN.
Was dit antwoord nuttig?
1 Opmerking:
Just deciding whether it's worth the risk (as the screen is a really pricey part).
My only worry is that even with a VPN, i will still get shut down on account of the serial number being potentially visible to Apple as a Canadian device.
I'm just trying to read around a bit on what the worst case scenario is if the tool doesn't work. If it's only losing true tone than I'm mostly OK with that - but if there are issues with local dimming zones, then that will make the screen essentially useless to me.
door
Voeg je antwoord toe
George K zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 16
Altijd: 345
